Currently I’m using iPhone 12. I am planning to upgrade to iPhone 15 or iPhone 14 pro . Which will be the best option based on battery and camera?
14 Pro will be good in terms of battery and camera overall sis. consider 14 Pro as you also get 120z display for better experience.
Will there be a price drop in the BBD sale for the iPhone 14 Pro? Had the iPhone 15 heat issue been resolved after the software update?
Yes sis. expecting it around 1 lac budget range. 95K to 1 lac mostly. iOS 17.0.3 fixed the overheating issue. so far reading positive reviews on that.
There aren’t any iPhone 14 Pro models available right now. Is it a good choice to go for the iPhone 15 from iPhone 12? How about the battery and heating issues, or should I wait a few more months for a detailed review from others?
Battery and heating issues fixed almost with 17.0.3 and we will see more refinement with upcoming iOS 17 updates too sis. its latest model, so dont worry about it. iPhone 15 models will definitely be good upgrade coming from iPhone 12. considering USB C, Dynamic Island, Brighter Pro model like Display and more battery backup time. overall it will be good upgrade.
