Im using jio esim on iPhone 13 and enabled all data settings for 5g but in myjio app it showing 5g handset settings not enabled. Tried to reset network settings after that 5g worked for few hours after that facing same problem
hi bro, whats your current iOS version?
Problem could be specific to your SIM or area bro. if you are using physical SIM, then do visit jio showroom once and get new SIM Card for same number and check bro. that will help fixing any network related issues too.
If you are using eSIM, then call jio customer care once and they will confirm the availability of 5G in your area. within 3 to 4 days a technician will call and visit your place to check everything. Whether problem is there at their side or at our device we will know it by then.
Ok bro nandri
Jio customer support ah contact pannen bro now the problem solved …
Good to know karthik. ![]()
