iPhone 13 Battery drain after ios17
Hi bro Iphone 13 ku can we update to ios 17 if update panna who was the battery drain problem is it normal or should wait for upcoming update bro. Ur suggestion
its almost new model bro. there are few bugs in iOS 17 but so far its good. you may update if you like to get all the new features mentioned in our video.
if there is any battery drain problem you may perform all settings reset and check. if you are worried about any such issues, then staying with current iOS version is good bro. you may update after few more updates rolled out in iOS 17.
