Hi brw i am using iPhone 13 i bought 20 july 2023 now my battery percentage 89 and battery drain fastly i charge 2 times per day
11 months 11% is normal bro. dont worry. but regarding the battery drain, sometime it could be software specific issue. how is your usage overall? do share last 24 hours battery graph with apps section visible.
tap on the last 24 hours and share the screenshot bro. this is last 10 days screenshot which dont show the needed details.
