iPhone 13 battery drain problem
i have been using iPhone 13, 10 months and in the last 3 month the battery has reduce 100% to 87% in normal use
hi bro, 10 months 13% reduce is bit higher. is your screen ON time high? how is your usage?
Average screen on time is 6h6m last 10 days and normal usage
Yes bro. thats good screen on time for 13 model. sometimes if we go to poor network coverage area, then battery drain will be bit faster. so each day it will be different.
Current battery mAh 2867
Cycle count ( number of complete charge cycles) 393 cycle
Current battery health 85
ok bro. in 6 to 7 months you may have to change battery at apple service center. continue the charging practice as suggested. not draining the battery frequently and charging the device around 20%. That will help you maintain it overall.
