iPhone 13 battery health is at 82%, Should I change now?
Bro my iPhone 13 battery health is 82%
Is this ok or I should change new battery
Only if you are experiencing fast battery drain, then you may consider changing the battery bro. otherwise continue using the device till it reaches 80%. install apple support app and locate nearest apple service center when the time comes.
