Hi bro, Na iPhone 13 use pandren bro,night pakum pothu battery 65% irundhuchu but morning patha 58% irukku use pannave illa yean brother battery percentage reduce aagudhu,any idea?
hi bro, 7% reduce is totally normal. network signal search, notifications and system service kaaga use agirukumnga. its normal only.
Okay brother thanks for your support
Bro night yarum call pana matainga na neinga flight mode on panitu sleep panuinga 5g on la iruntha off panuinga bro it’s take more power for signal strength then background apps la clear panitu check pani paruinga bro.i hope it will help for you.
Sure bro,Try pantren
irobin bro iphone 14 pro max battery price evlo varum any idea please update
It will come at Rs 9800 bro. You can check at apple website.
