iPhone 13 Charging very slow
Past two days ah phone romba slow ah charge eerudhu iPhone 13 use pandren idhuku munnadi Ipdi naan endha issue uhm face pannadhu Ila ampere test app laiyum run panni Pathuten avg 9-10 w than Kaatudhu , wire maathi use pannen apo konjam fast ah charge eerudhu as useful normal ah but same charging speed tha kaatuchu Andhawire use panna apovum so ipo naan Ena pandradhu new wire vanguardha ila ena pannanum bro ?
hi bro, new cable la once try pannanumnga. suppose old cable la iruntha intha mathiri issue varalaam. sometimes adapter la issue irukalaam but vera cable try pannathulaye nalla charging speed iruku appadina cable thaan issue va irukum. from 0 to 50 and then 50 to 80% charging speed difference irukum. fast charging is moderate level in iPhone 13 model, not fully supported. so cable mathiri check pannuna theriyumnga.
