iPhone 13 Clash of Clans Icons are Small, How to Increase?
Do submit a request to Byjus development team bro. they can release it for iPhone and iPad. Otherwise we have to use it only via Safari browser if allowed.
How to submit our requirements bro ? Any app or did you know mail id bro
Yes bro currently using those websites through safari …
I dont have Byjus contacts bro. within app contact details irukaanu paarunga. or you can search their website - contacts or about us page.
Okay bro check panura
Another doubt in camera section
Closer object correct ahh focus aaga maatuthu,konja Pinadi ponadha focus aaguthu …!
Ithu yen bro
Yes bro. 13, 14 models la macro lens kedayathunga. Only in Pro models we can take closer object photos clearly. Otherwise we need to maintain small distance to take the picture clearly of closer objects.
Okay bro .
Understood and fine !
Charge potathuku aprm
25% to 75% <— between this charging percentage- mobile and Apple adapter heat aaguthu . Why ?
After 75% - cool down aaguthu
My doubt is heat aagurathu nala battery and adapter ku problem Etha varum aah??
during fast charging it heats up bro. in between any level if it detects overheat, then charging speed automatically reduced or stopped. it will continue once temperature drops.
charging appo phone use pannama irukarathu better bro. during this summer season room temperature mostly higha irukum. so heating is normal on electronic devices.
Charge podum pothu na use pana maata bro …na irukurathu ootu veedu bro antha alavu heat irukathu bro …!!
Charge podura apo heat aagurathu normal thana ahhh bro or issue vaahh?
Ithu matum confirm panuga!!
Charging appo heating normal thaanga. dont worry bro.
Okay bro , fine
Hi bro
How are you ?
Tim Cook kooda photo eduthingala apple bkc la
My doubt is
Steps calculation Apple Watch llama
iPhone la calculate aagurathu correct ahh irukum ahh bro ?
Illainga :slight_smile: It was very restricted meetup. and tim cook left the place shortly after store opening. will wait for next time when he comes to India.
Also questions ku separate discussion topic open pannunga. if the question is related to apple watch then antha category la post pannuneenga na organise pannurathu easy bro. kindly copy paste this question into separate topic under apple watch category.
Okay bro
I’ll copy paste the question
