iPhone 13 Clash of Clans Icons are Small, How to Increase?
Hi bro
I’m iPhone 13 new user .
Clash of clans game la ulla icons la small ahh iruku …konja perusa iruntha nala iruku.
Any suggestions from your side !!
hello bro, kindly share screenshot of inside game and icons to understand.
Screenshot Edith’s 13mb poguthu bro …128kb tha allowed nu potu iruku bro …what to do now ?
IMG_0012
Check this bro !
imgur.com website use pannitu upload pannalaamnga. just link inga copy paste pannunga.
okay bro
Upload panitu update panra ithula
and
kindly check this video once
can we follow this video !!
Also new iphone purchase panathunala - 3month ku free apple arcade koduthu irukaga …Use panulam ahh ?
3month aprm stop aagidum ahh or nambala pay pana soluvagala bro ?
Saw the video bro. you can use some of these features. its useful ofcourse. they explored all the features in one video. its good.
Yes bro. trial venumna use pannunga. see how it works. renewal agurathuku munnadi neenga subscription cancel pannikalaam. auto debit aagathunga.
okay bro (both the replies from you​:star_struck:). really thanks for the reply !:green_heart::green_heart::green_heart::green_heart:
check with this images bro @iRobinPro
icon’s small aahh iruku paarunga …
kindly reply …!
screen kum icons kum oru gap iruku paaruga
do perform “Settings - General - Reset - Reset All Settings” once bro. some accessibility feature change a irukalaamnga. try that and let me know if its fixed bro.
okay bro update panura ungaluku …
Bro reset Panita no changes bro :pensive:
data ellame cloud la save agidumna. once app reinstall pannitu check pannanum bro. can you try that?
Check panitu update Panura bro …!
Re-install pani paathutan, it remains same bro
Next thing is ,
Na night mobile data, Wi-Fi, Bluetooth la off panitu padukura but mrng enchi paatha Wi-Fi on la iruku bro :thinking::thinking::thinking: epd nu therla , oru three days ah notice panura
within game graphics settings option irukungala? can you check and adjust the game graphics settings to full screen ratio if available?
second, control center la off pannumbothu morning 5AM around ON aagumnga. both wifi and bluetooth. Permanent off ku settings app ulla poyitu off pannanumnga.
1st - Okay bro check panitu update panura bro ungaluku
2nd - Ohh ipd oru visiyam irukaa bro iphone la :exploding_head::smile::smile:.Okay bro settings ulla poi off panikira enimal
:slight_smile: also intha mathiri shortcut namma use pannalaamnga. just additional option.
Okay bro . I’ll check this video
Thanks :pray:t2: for your all replies bro .:sparkling_heart:
irobinpro
Regards
Apple User
Bro ,
That Bluetooth and Wi-Fi problem solved.
Charge night vakum pothu 47% irunthuchi
Mrng paatha apo 43% iruku … How :thinking:?
Good to know bro. upto 8% is normal don’t worry. Location Services, Network Search, Notifications, and background usage ku consume aagumnga. it will keep on changing every night.
Okay bro . Okay
Fine :innocent::innocent::innocent: and testbook app , Byjus exam prep app App Store la ila bro …ithu tha konja varutham
