iPhone 13 Heating and Lagging Issue, How to Fix?
Heating and lag issue issue For iPhone 13 storage not full maintain any solution
Hi bro, try restarting the iPhone once and check if the problem is fixed. Usually, it’s a RAM management or memory-related issue that gets fixed with a simple restart.
If the problem continues, we can do “settings—general—reset—reset all settings” once. That will help, too.
Let me know after 3 to 4 days usage after above troubleshooting steps whether you are seeing improvements or not.
Ok bro I will check it and told thanks for information
