I have iPhone 13 Pro Max and I did the latest update 26.3.1 and after that the keypad speed is slow and there is bit of a lag
Is it a normal expected one or what should I do
Some of my friends having the latest models iPhones also feel the same
hi bro, whats the current battery health percentage of the device? any battery replacement done recently?
Battery health is 78
Not replaced yet
battery health is one important reason here bro. if you notice any app crash or other hangs while using normally, then consider changing battery if you are planning to use the device for another 2 years. that will help fixing it.
Ok thank you
I have got about 80 gb in WhatsApp I am not able to back up it in iCloud
I have got iCloud free space puns 75 to 80 gb
Is there any other alternative to backup whatsapp chat in son cloud
I have Google Dirve for 2 tb also
First we should turn off low power mode to let backup run in the background bro. make sure to leave iPHone connected to charger and wifi connected, that will run the background uploads for system and apps.
Try to reduce the storage overall inside whatsapp settings chats and storage. groups, individual chats specific data storage duplicate data or unwanted media contents can be deleted. this way you can clear out more space and upload will be lot easier.
Google drive not useful here. Whatsapp only uses iCloud service with iPhone.
