iPhone 13 mini Battery Replacement
I am using iphone 13 mini since its launch.
My battery health is 84%.
Is it ok to replace battery or move to new iphone.
If new phone means what would be your suggestion.
hi bro, once battery reaches 80% and you notice fast drain problems, then you may consider changing battery only if 13 mini is suitable for your usage. Otherwise you may consider iPhone 14 as minimum model to consider for better user experience in 2024.
to use the device for another few years. if possible experience the device at nearest apple showroom bro. check 14 and 14 plus. coming from mini model plus could be bigger to handle. but it has bigger display and battery too.
So personally check and see which one would be good choice for your next few years usage. if budget allows going with 15 also smart choice. dynamic island and usb c port with brighter display as available options.
Ok bro thank you
