Hi bro
Few days ah en iPhone 13 la Olunga charge aaga matingudhu … wire shake aana apdiye stuck agidudhu idhu Enaku mattum than iruku wire problem nu nenachen en frnds 3 perukum ey indha problem than Idhe pola charging apo phone charge aagama apdiye stop aagiduchu
Hello bro, I have checked in my iPhone 12 and so far no similar issues found. cable or loose connection iruntha intha mathiri aagalaamnga. possibilities are there.
issue perusa illati continue pannunga. otherwise service center la check pannanumnga. mostly charging port area replacement panna solluvaanga which will come around 12 to 15K range.
Ila bro Enaku mattum indha Prechana irundha Oky ..en frnds uhm Idhe problem than recent Time la face pandranga adhan ungalta kettu innum niriya per Idhe pola face pandrangala ? indha issue oru 1-2 weeks ah than iruku bro
Puriyuthunga. same issue other users kum iruntha kandippa problem irukum. loose connection issue mathiri thaan theriyuthunga. but other users kum same issue vanthiruka koodathu. vera cable ethavathu try pannuneengala?
Yes bro , issue face pandra Ellarume wire change panni pathom , but issue continue aagitu than iruku new cables maathunalum Idhe issue continue aagudhu , what we can do bro ?
once service center la oru device check pannanumnga. diagnostics or technician check pannurathula thaan identify panna mudiyumnga. enna specific reason naala intha issue iruku nu identify pannanumnga. kindly check and let me know bro.
