iPhone 13 or 14 Pro? Which is Best for Vlogs?
Iphone 13 pro or Iphone 14 pro for vlogs…and better battery backup
Both cameras are excellent for vlogs, bro. Pro models have a slight advantage regarding Rear Camera performance and processing. So if budget allows, you can go with 14 Pro. It has best Front Camera as well. You will find it very useful.
Only for budget reasons, you may pick up iPhone 13.
