As per our convo. No bro I haven’t faced any green tint problem. Now also my display looks and works good only the touch is not working. It’s been only 1.5 yrs since I bought the phone. I don’t know what’s the problem. I’m blank right now. I took it to apple support i.e service centre they simply said display needs to be changed. I bought apple because of their longevity.
Hi bro, you can create separate discussion topic to maintain our discussion as one thread. Apple products does work well for years but such rare cases are disappointing bro. did apple service technician found any internal or physical damage?
otherwise as I said in our green screen video, we can proceed with legal options. If service center confirms no damage caused by user, even for out of warranty product you can consult a lawyer and file a complaint with consumer court to raise this problem.
After software update that the vendor have bricked your device and its not your fault as per the details provided by authorised service technician. That is the last step we can do bro. Consulting a lawyer would be appropriate step in such case.
