Iphone 13 pro max network issue
When connected in a call i cannot use my cellular network the network goes so down sometimes it doesn’t show signal also but the call will be connected. Please help me with this problem bro
same problem i face in iphone 11 also
hi bro, is it physical sim or esim? @maniapple23
i use jio e sim bro and physical sim
I use both esim and physical sim bro trying calling to some one use airpods and try searching something in safari
Problem happening with esim or physical sim bro? In both cases it is important to replace sim. If its physical sim then visiting store and getting new sim for same number is recommended. If its esim then contacting customer care and then remove and reconfigure esim to fix such no signal problem.
Let me know if that helps bros. @maniapple23
in both sim also this problem is happening bro,while the call is connected the signel goes down but the call is still connected.i recently change my esim from airtel to jio bro for this issue but the issue is still not resolved
It could be ios issue bro. You can perform ios restore once and see whether the problem fixed or not.
