Hi irobin bro My Samsung note 20 ultra display went black after Android update now i’m moving fully to apple ecosystem but i have seen your recent video on IOS16 update gives green tint issue to 13 series model. Im planning to buy iphone from Dubai suggest me best mobile because 13 series having green tint issue and 14 pro and pro max recently started to have lines in there display after IOS16.2 update just now saw in twitter also some people are saying 14 pro series are not giving good battery life . I’m really confused to choose between 13 pro max or 14 pro price constraints.
Both these 13pro max and 14 pro are same price in dubai.
hello bro, as I mentioned in the video, very few users affected by such problem and when the issue not caused by user apple will bring a replacement program to change the display free of cost. few users did get their iPhone 13 pro and pro max display replaced for free after green tint issue.
You may get applecare+ just incase while buying iPhone 13 pro models at good pricing and offers. 2 years whatever the damage we cause or if there is any manufacturing defect, it will be covered. not to worry about that.
if you are short on budget, then you may pick up 13 pro max for better battery performance overall too. I hope it helps.
Actually 13 pro max and 14 pro are same price consider this situation what will you go for bro is this new 48MP camera and dynamic island is much needed one?
I would pick 14 pro max when both are in same price bro. One step ahead processor and camera are big advantages.
