iPhone 13 Pro Max to 16 Pro, Worth to upgrade?
Hi bro
I am planning to upgrade from 13 pro max to 16 pro
Is it worth upgrading
hi bro, you will notice some difference in terms of bigger display, brighter display, dynamic island, usb c and better camera system for sure. If you are ready to upgrade then yes. its good to consider 16 pro.
but remember, battery performance wise 16 pro is meant for average users. max model always have bigger battery. so decide based on battery backup you need too.
Now my battery health is 82% bro otherwise shall i upgrade to 15pro max it’s good choice
If budget ok means go for the upgrade bro. otherwise if 13 pro max meets your every day usage then changing battery once it reaches 80% will be good idea too. upgrading after 2 years of usage will let us feel the difference in terms of features.
