iPhone 13 sudden temperature goes high ?
Bro enoda iPhone 13 sudden ahh temperature raise aaguthu then na switch off pani on pana normal aagutu ?
Antha sudden heat Athunala aachi ?
Note : background la apps ethum run aagala!
updated to iOS 17.1 bro?
Yes bro updated bro
Just once intha mathir aachuna not to worry bro. repeated a normal usage ku overheating aguthuna once all settings reset pannitu use pannunga. again problem repeat aachuna iOS Restore is must to fix overheating problem bro.
Okay bro .!
