bro currently im using iphone 13 im planning to upgrade my iphone 13 to iphone 15 pro max with exchange in apple store my iphone 13 they are taking for $300 usd so after that iphone 15 pro max is costing $962 usd now what i want i should wait for 16 pro max or go with iphone 15 pro max mainly i want to know that would the exchange price of iphone 13 will go less when 16 series launched
hi bro, resale value of used iPhone 13 around $300 is OK pricing. in 2 months I dont think there will be big difference. so if you can manage for 2 more months then you can opt for 16 pro max trading in iPhone 13 model. I think the trade in price difference will be same bro.
only if its urgent and 13 is causing any battery issue or performance issue you may go with 15 pro max. its still worth for next few years usage.
ok i will wait for 16 pro max
I am using iphone 12 currently .I am looking for upgrade .Can you please suggest me which variant will better .Iphone 15 pro or iphone 16 pro or any other variant is also fine.Can you please suggest.Thanks Robin bro in advance
bro if ur budget is high u can choose for iphone 16 pro if ur looking into good offers u can choose iphone 15 pro in iphone 16 pro there is capture button and 3 hrs more battery life thats it so yu can decide further based on ur recommendations
from 12 to 15 pro or 16 pro both are upgrades bro. as vishnu bro highlighted, its the budget we have to decide here. if you need the latest hardware and budget isnt a problem go with 16 pro. If you find good deals on 15 pro then go for it as it has best hardware and suitable for next few years usage bro.
