Hi Sir
Currently i am using an Iphone 13
Is it right time to upgrade for Iphone 16 pro, (Never used an pro models before)
minimal usage
My main question is which to pick 16 are 16 pro
Hi bro, both iPhone 16 and 16 pro good upgrade. for most users 16 is sufficient. If you are budget focused and need most of the features offered then consider 16 model.
Only if budget isnt a problem but you need 120Hz Display and Pro Camera system then consider iPhone 16 Pro. that will be good purchase then.
If possible do experience both models at nearest apple showroom once. that will help you to decide better bro. as both models are above 80K budget range.
Thank you so much for you suggestion bro
Thanks for taking time to replay for this question ![]()
