iPhone 13 to iPhone 16 pro max upgrade doubts
i want little advice from yu bro currently im using iphone 13 with broken display bro my relative is coming from usa on march so i have planned to buy iphone 16 pro max what are the major changes i will feel from iphone 13 to iphone 16 pro max than larger size and 120 hz promotion is it worth to upgrade to iphone 16 pro max i tried to change the display of my iphone 13 but it is coming as the iphone 13 rate now in flipkart mainy my aluminum case also damaged so that also should be changed so what would yu advise me to do repair the iphone 13 or buy iphone 16 pro max (iphone 13 damaged but completely everything working 100% fine)
Hi bro, from iPhone 13 to iPhone 16 Pro Max is a good upgrade choice. You will notice the following differences.
  1. 120Hz ProMotion Display
  2. Bigger Size Display with Bigger Battery and Good Backup.
  3. Dynamic Island feature
  4. USB C Port to use Pen Drives and SSD Drives
  5. Sharper and more powerful Camera system
Action Button, Camera Control and other features you will start to use every day.
If you are short on budget you may consider repairing iPhone 13 display and continue using it for some more time bro. if original display cost is high, you may check with third party service centers for display price at half or even less sometimes.
So decide based on budget and after once checking with repair possibility at third party service center if you are ok bro. One more thing, once device serviced outside, we have to service it again in third party only incase of future issues. not possible to service it again at apple service center.
actually bro my iphone 13 aluminum case is also broken the service center saying once we open the mobile to change display the aluminum case again cant be fixed together because it is also broken so now they are saying i need to change complete aluminum casing and new display so is it worth to service then one major thing they say is it will show “UNKNOWN COMPONENT” in settings
possible bro. the damage could increase when they try to service. in that case if you want, you may check with third party service center for repair possibility. if you are around chennai check with iPick Service center once too. to make the device usable again if you want to.
tried ipick service in shanthi colony anna nagar and gofix anna nagar both are asking about total 25k for both full aluminum case and display but both saying it will show unknown component because of third party spare parts
Got it bro. thats possible as we change non genuine accessories. in this case only option left out is, selling the phone for available spares if you dont want to keep it with you or spend more further bro. decide according to budget in this case.
Bro US la irundhu varangana - 14pro max - apple cerified refurbished oru nalla option ah irukuma
1lakh ku 1tb storage option oda vandurudhu
Yes bro. apple refurbished ku 1 year warranty um irukumnga. but 1 lakh budget poreenga 15 Pro max india la ye imported unit with few months warranty oda eduka chance irukunga. athuvum check pannunga. ennoda 15 pro max india la imported unit thaan buy pannunean. exact 1 lac for 256GB Storage model almost 5 to 6 months before. with 8 months warranty left I think.
So sellers local aavum check pannunga. you may be able to find good units with warranty here.
