iPhone 13 Whatsapp audio silent problem
iPhone 13… While seeing whats app status I’m facing that sometimes that the audio is silent in between.
How to fix this issue?
This could be whatsapp specific bug bro. Is the app updated to latest version?
I have faced same issue. Force close the whats app and open again. It will get fixed.
Yes bro,
It’s up to date.
I facing this problem from when I bought the phone.
You may try whatsapp offload method to reinstall whatsapp without loosing the data bro. See it gets fixed or not.
If its whatsapp specific problem we can see it getting fixed with upcoming update bro. do send a feedback to whatsapp within the app help section. make sure you are running latest iOS version too.
