Hi Bro I am using iphone 14 for last 10months My warranty period is going to end in 2months and My battery health was 85% the battery change was eligible with that warranty or not (note : I don’t have care+)
hello bro, within warranty if the battery health reached 80% and any defect found we can replace battery under warranty bro. other than applecare+ do check the price of Protect+ at iPlanet service center. you can get it within 1 year warranty period.
We can claim for battery and entire iPhone similar to applecare+ for the next one year if protect+ is applied bro. check iPlanet care for possibility.
Compare the price with battery replacement cost and if battery health reaches 80% within this next one year period then you can get free battery replacement done. It is possible. but just once check with iPlanet staff before getting protect+ too.
That will be helpful.
