hi bro I am using iPhone 14 i bought one week before I am facing overheating and fast battery draining issues what can I do.
Good morning bro. Dont worry, its a temporary issue. make sure to update iOS software to latest version and with a proper case, you wont feel the heat directly on hand. This heating also gets reduced over 2 to 3 weeks of usage automatically. heating happens during Camera app usage, video recording, HDR video playback, gaming are normal.
if you are noticing heating continuously even for normal usage after 3 to 4 weeks of your iPhone usage, then consider visiting apple service center once. they will take backup and perform iOS Restore once.
That will fix any iOS related bugs causing such heating problem bro.
But I am facing normal usage also
I understand bro. do perform тАЬsettings - general - reset - reset all settingsтАЭ once. then see for 2 days how it goes.
apple care+ podalama bro
yes bro. applecare+ available and within 60 days la activate pannura mathiri irukumnga. after that Protection Plan nu apple india puthusa launch pannirukaanga. I am getting the details about it. will share the info by tomorrow or day after episode bro.
bro eppo battery health 1% reduced
Do calculate battery health over 5 to 6 months once bro. if there is a defect within 1 year warranty period you can get it replaced. dont worry.
where did u buy the charger adapter bro?
imagine Store bro
