iPhone 14 camera lens damaged
today my iPhone was fell in road and i got my camera lens damaged (orginal lens) i need to replace it . And I don’t trust the local shops for this replacement , luckily my phone and camera was completely fine . What should i do now?
sorry to know about the accidental fall and damage. at apple service center it may be expensive but we need to check repair possibility once bro. when it comes to chip level service or alternative option third party is the only way we have to fix such issues.
If you are around chennai you may check with iPick Service Center or iDot Repairs to see approximate repair cost.
But device once serviced outside cannot be serviced again at apple service center. IF thats ok you may check this option to fix it bro.
If you are around coimbatore check with iPlace or GoFix too. based on your location and budget decide bro.
Hi bro,
currently my device is out of warranty i checked it with apple service centre they told they will replace the entire back glass panel and it will cost around 17k and it is not worth to change it only my camera lens was broken i dont trust the local shop for the lens replacement coz they may stole the internal parts
That will be expensive repair bro. are you ok with the back glass replacement or planning to go for an upgrade? decide based on budget plans bro.
bro , i need pulled out oem parts with best price
do check with iDot Repairs or iPick service center in chennai bro. google search and give a call to them to know possible spare availability and pricing. they may be able to help.
