iPhone 14 crashes & legs & overheat after iOS 18.5
Since updating to iOS 18.5 on my iPhone 14, my phone has become nearly unusable. It crashes every 5 to 10 minutes, overheats, and the battery drains rapidly. Each time it crashes, my hotspot disconnects automatically. I’ve already tried restarting the device and resetting system settings, but the issues persist. Is there any solution Bro?
hi bro, whats the current battery health percentage of the device? any battery replacement done recently?
No bro, not any battery replacement is done it’s original battery only & before installing 18.5 it was 87 & now it was 85 in 2 days bro can i move on to 18.6 beta because i can’t use the phone now crashing so much.
I understand bro. then the issue could be due to some problem with files received during update. iOS 18.6 update release expected today or tomorrow bro. meanwhile you can try taking backup of your iPhone using computer and then perform full iOS Restore once.
Then restore your backup. When iOS 18.6 comes out, you can update it within iPhone.
Make sure to download iOS Software updates only with stable wifi connection. due to network packet loss in mobile data we may experience such issues.
Okay bro
