Hi bro I’ve been using 14plus for past 42 days and one day I use up to 11hrs I’m a heavy user…my battery health is currently at 98%… this health drop because of my usage?? I maintain my charging cycle at 20 to 100%
Yes bro. when there is heavy usage, battery health will drop over the period. Its all about usage. our charging practice helps us to maintain the gradual reduce. dont worry. keep using the way you want it to. overall you will get 2 to 2.5 years based on your usage.
Just confirmed with apple india website, that Family Setup with Apple Watch Cellular is not compatible with Indian Mobile Networks. They may be announcing it in future with a dedicated Smart Watch plan.
Ok bro thanks for ur reply☺️
