iPhone 14 plus incoming calls problem
iPhone 14 plus 14 month old incoming voice is feeble remedy pl
Regards Ari
hi bro, if its due to dusts, then cleaning ear piece area could help too. when you turn on speaker mode during calls, does it sound the same or clear voice? can you check once and let me know.
Bro could you suggest basic tools to clean iPhone especially earpiece, charging port and speakers
To clean ports and speakers I am using this method bro.
You have to press it gently to avoid getting those tack it stuck inside the ports. be gentle while pressing with speaker grills and mic grills especially.
as I am using tempered glass, I simply use micro fiber cloth and rarely little hand sanitizer to clean the surface of the tempered glass and all around the iPhone.
So far it works well bro.
