Hi Bro,
Your videos are very much informative. I watch your content regularly.
Currntly im using iphone 13 & planning to upgrade to iphone 14.
Have planned to buy from USA. So kindly guide me which one would be best choice ? Iphone 14 plus or iphone 14 pro or pro max.
Regards
Vijay
Both iPhone 14 Plus and 14 Pro are good Buy. But if you have iPhone 14 Pro Max, in your list, then go for it bro. Plus model have good battery backup and bigger display like Max model as I mentioned in our 14 plus review videos in our channel.
Pro models have the Pro Display and Pro Camera system. So If budget allows, and you want the best experience with iPhone latest technology in place, then Pro models are definitely best to consider.
To choose between Pro and Pro Max, you may experience both of them once at apple showroom. Size, Weight, Display quality and camera experience will help you decide better. Both have same camera system but if you have any doubt regarding the handling of the device, then its good to have a hands on experience once to make a final decision.
