iPhone 14 Plus Screen Warm Yellow, Any Fix?
Bro , Iphone 14 plus la Screen Warm (yellowish) iruka matam feel aguthu any solution?
Same doubt here @iRobinPro
Hi bro, its new iPhone and true tone display ON la irukum bothu light warm tone add aagumnga. dont worry about it. Settings - Display & Brightness - True Tone toggle OFF Pannitu check pannunga. Also Apple oda 2 Display manufacturers pannura display la light difference irukumnga. But apple oda color calibration always stays same bro.
True Tone off la than Iruku bro check the SS pic …and Diff iruku
I think Temper guard probs ah irukuma?local temper than ottunee
Suggest me Good temper and back case bro, Iam using purple colour mobile
chance irukunga. sometime tempered glass issue irukalaam. but display la ethuvum issue illa nu once confirm pannikonga. visit apple service center once. as its under warranty they will run free diagnosis and check whether any problem is there in the display or not.
service center la ethuvum issue illa nu sollitu normal la use pannunga. dont worry.
