iPhone 14 Plus to 15 or 15 Plus upgrade worth?
Hi, am currently using an iPhone 14plus Is the 15 or 15 plus upgrade worth it, or will i wait for the next series(16)
Hi bro, USB C port, Dynamic Island and Increased display brightness are the differences. If you get good resale value for iPhone 14 Plus, then you may consider upgrading to iPhone 15 Plus. Otherwise staying with 14 Plus and upgrading next year atleast would be great.
You will feel more difference while using the device coming from 14 Plus.
