iPhone 14 Plus to 16 Plus Upgrade Worth?
Am using 14 plus is it good time to upgrade for 16 pro max , will there be any difference?
hi bro, yes from 14 plus to 16 pro max it will be good upgrade. you will see 120Hz Display, dynamic island, USB C port, good camera improvements and better battery performance as well. 4+ hours of battery difference.
Thanks,
