Hi Robin bro and other people I bought a iPhone 14 Pro last week the battery life was great at start then I updated to the latest version of iOS 16.5 and also changed my primary sim to esim after these the battery Life became bad it drops 10-12% in a hour also at idle time while im sleeping it drops from 43% to 37% is this normal or any issues ? these are from Friday and Saturday ive asked apple they said as your iPhone is updated for the first week it would be like that after a week it’ll become normal
hello bro, based on our usage and network conditions, battery performance difference might be there. also when we update to new iOS version, if there is any optimisation needs to be done, it does consume bit more battery power overall.
You can reinstall instagram app once, perform all settings reset if the issue continues for more than 3 to 4 days.
else it automatically adjusts and you start to get same battery performance as before.
