Hi bro, I have been using a 14-pro iPhone for the past five months. My battery health is 95, and I updated 17.4, so there is also a battery drain issue.
hi bro, with increased instagram usage we do notice such fast battery drain. iOS 17.4 update does have some issues related to battery drain and screen off time, expecting a fix very soon. in above graph we can see that from morning 9 AM till evening 9 AM the battery consumption is gradual and you still have 40% around left.
So dont worry, continue following the same charging practice like charging the device when it reaches 20% and it will be maintained over period of time.
Okk bro thanks
Try to turn off background refresh for social media apps bro. They are not priority. So it’s better to keep them off.
its normal bro. for apps notifications, network signal search it uses battery power overnight. if its above 10% then we can try some troubleshooting steps. for now it will keep on changing in upcoming days. dont worry.
