Hi Bro, I bought iPhone 14 pro on Sep 2023 now battery life reduced to 94% is that right or need care on that?
Current ios version is 16.4.1
7 months 6% is normal bro. dont worry. continue following suggested charging practice. it will be maintained well.
Okay ng bro… Thank You…
I have Apple care for 2 years at what stage or percentage in service centre they will replace battery?
Yes bro. if it reaches 80% within warranty period you can get it replaced under applecare+.
