iPhone 14 Pro Max Battery Health 86%, What to do?
Battery health of 14 pro max is 86 percent after 14 months followed your battery tips also as an average i use 70% of my battery per day using 12w ipad charger and 20w belkin charger
Hello bro, the charging practice we follow helps to maintain the Battery Health. for some users even if its not reduced this month, it will be reduced in upcoming months. In your case, some months it wont reduce.
Dont worry about it. continue following the charging practice suggested.
Overall 2.5 years it takes to see that 80% reach for average users bro. You are already doing correct practices. so dont worry.
