iPhone 14 Pro Max Battery Health and iOS Update
strong text
I’m using I iPhone 14 pro max right now my Battery health is 87% still I didn’t updated 17…4. Can you check that the attached screenshot bro.
hi bro, battery graph looks stable and good. if you are still using iOS 16 and finding now issues you may stay in the same version. But if you like to use iOS 17 features, then you may update and see bro.
Right now I’m using 17.3.1 bro. Can I updated the 17.4 bro.
not recommended bro. as I mentioned in yesterdays follow up video, its good to wait till 14.1 update comes out.
