iPhone 14 pro max case suggestion
Hello @iRobinPro Merry christmas wishes to u and ur family.
Pls suggest me a case for my 14 pro max.
I m now using Caseology by Spigen Nano Pop Mag Back Cover Case.
I need a silicon case with raised camera lip under 1k price.
Kindly suggest.
Thank you bro. :heart: If you prefer something under Rs 1000 budget range then you may check the following type case.
Some of our users also using it.
Additionally, you may check with Amozo brand case, they do offer good quality and well designed cases under 500Rs price range too.
https://amzn.openinapp.link/1m6ar
choose the design according to your choice bro.
