Hi bro, I am using iPhone 14 promax, one sim physical and another sim is esim bro. Now I am using esim bro,
But another iPhone how to add esim. Another iPhone is abroad, how to transfer esim please bro.
hello bro, eSIM transfer can be done by contacting the mobile network carrier. They send QR Code to eSIM transfer to your registered email address. When you scan the QR Code in your new iPhone, then the eSIM will be successfully transfered.
If the iPhone is in another country, then contacting the carrier will be difficult. try sending an email to them. To avoid anyone initiating transfer request of an esim, they verify your id and then proceed with the transfer.
Ok thanks bro
