iPhone 14 pro max I am using 30 minutes heating issue before 17.0.3 update
Could be iOS 17 related issue bro. some users are experiencing it. were you using any specific app like instagram reels or facebook videos when you notice heating?
Yes bro older than 2 year sim bro. Visible top icon 4G&5G display bro,but network is very slowdown.
Do visit the network showroom and get new SIM card for same number or convert it to eSIM bro. then check how it works. mostly older sim firmware issue va irukalaamnga. VoLTE connectivity means we get good speed overall. at present Jio 5G is facing network issues in many areas.
I too experienced slow speed and call disconnect while using 5G Only mode. after changing it to LTE its working much better now.
Ok bro thanks ![]()
Hi bro, I am using iPhone 14 promax i am using Airtel network yesterday my phone network problem issue bro. Any solution bro please.
Airtel network is experiencing problem in many cities bro. you have got new airtel sim card recently correct?
updated to 17.4.1 bro?
