Hi everyone…i have a confusion of buying a new iPhone…this is my first time to buy a iPhone…i had lot of thinks in my mind of buying a new phone…money doesn’t matter of buying…but the product should be worth and long lasting…in one side iPhone 14 Pro Max was in choise…the performance was good and all ok.but the service and spare cost was so High compare to 15 pro Max…in this side 15 pro Max was little warming…build quality…and little issues was confusing me about to purchasing it…is anyone using 15 pro Max kindly share your feedback of purchasing it …@robin bro…if you read this kindly share your opinion and experiance about this and pls contact me
hello bro, both 14 pro max and 15 pro max are good to choose right now. that backglass durability problem is not observed by few of my friends using 15 pro and pro max models. one of my friend using it without case and not facing any issues till date. the same for overheating. as I said in our video, overheating already fixed under normal usage.
So if 15 pro max fits your budget go for it. you can wear proper tempered glass and case to prevent damage with common drops and hits.
Experience iPhone 15 pro max once at showroom. its 20 grams lighter than 14 pro max model. 14 Pro Max feels more premium with its stainless steel sides if you dont use it without case and added 20 grams weight isnt a problem.
Otherwise 15 Pro max will fit perfectly with overall usage. you may consider applecare+ to get 2 years full protection if necessary bro.
