iPhone 14 pro max vs 15 Plus, Which is Best Buy?
Bro what’s the best between 14 pro max and 15 plus in terms of money and reliability now… what’s your opinion anna
Hi bro, both are excellent buy and if you can find 14 pro max around 95K range for 256GB Storage, then its more value for money and reliability for upcoming years. even it will be good with resale value too.
