Is it okay to use my iPhone in low brightness, like below average (See image). I use my iPhone at this brightness all the time, (5 months old iPhone 14 PM) and now I felt like my iPhone screen kinda yellowish tone, (I’M NOT SURE THOUGH) I can’t notice the different accurately. Is not that yellow but I can feel the difference, but again I’m not sure.
Am I having any yellow tint? (See Image) also I’m using screen protector (4 months old) may be that’s the culprit? because I kinda feel the yellow tone only in certain angle so…
One article said dim brightness can cause yellow tint temporarily (See Image),
But I never put my iphone in low power mode for once till now but I kept my brightness in below average all the time that’s why I confused.
Hi bro, Is the true tone feature ON under settings - displaky & brightness - true tone? This feature normally adds mild yellow tone to avoid more blue light. Also in screenshot we wont be able to see that yellow tone bro. you may see it on the display and possible our screen protector could cause such issue. But within warranty period to know its defect, we can check with apple service center.
But as a basic diagnosis at apple service center they will remove tempered glass if any applied. Perform All settings reset and check too. You may check with nearby service center once to confirm the same.
It looks normal in this image. You can visit apple service center once as the phone is still under warranty and get it checked by a technician bro. if there is any issue they will guide you further. Other than true tone we can adjust the colors we see in the display from accessibility settings too. But that wont be necessary here.
Just check once with service center and it will be alright bro.
