iPhone 14 Pro Stock Availability and Where to Buy?
Hi,
I’m a Android user looking forward to change to ios.
What are the pre requisite that is essential as an android user changes to ios/iPhone. What are the do’s and don’ts.
Also I’m planning to buy a iPhone in 2023. Any updates like when the stock for iPhone14 pro will be back. Which place is best like iplanet/Aptronix/croma?
Hello bro, It is important to try iOS with your friends iphone or at apple showroom for few minutes to see whether the UI and Design looks comfortable to use or not.
  1. Check the apps you normally use in android are available in iPhone appstore also,
  2. Things you normally do in your android device can be done in iphone also, but with some apps, shortcuts and two or three steps work around.
  3. You can search our youtube channel with one word to find such iphone tips and tricks too.
Stocks will be available next month mostly, but you can check with apple showroom once for availability too. Some models and storage options are available. Else they will take preorders and mostly deliver it in couple of weeks or maximum in a month time. I hope it helps.
