iPhone 14pro max battery percentage reduce
Hi @iRobinPro
How are you?
Bro i m using 14 pro max for almost 21 months.
The max battery percentage showing after updating to latest 17.6.1 is 90%.
Is this percentage an actual max capacity of my battery.
When we use some battery status in shortcuts it shows around 84%.
Hi bro, I am good thank you. hoping you too. The battery health page stats is sufficient. for 21 months usage 10% reduce is totally normal and good. continue following the charging practice and that will help to maintain it overall.
no need of any shortcuts. once battery health reaches 80%, check with apple service center for battery replacement if you are planning to use the same phone for another few years.
Hi bro iOS 17.6.1 update epdi bro irukku
