iPhone 15 Batter Drain Problem, How to Fix?
Its iphone 15. I texted you yesterday about this. Is this battery drain normal or not?
Hi bro, Instagra and Personal Hotspot consumed more battery power. it does look normal as Hotspot takes more power normally. especially if you were using 5G then battery consumption is bit faster for our usage.
Avoid using low power mode tomorrow and use the phone normally as you would. if possible use the phone without personal hotspot and share the graph tomorrow evening.
Charge the phone to 80 to 100% and dont charge in between. that way we will be able to know whether it comes 1 day for your usage or not.
Thank you for your time and reply
This is today’s battery usage. In 4 hrs it came from 89-31% .
Na android la irunthu ios use panrathu naala enaku over ah teriyutha? Illa apple phns la ipdi tha usual ah vey irukuma? I just wanna use it tor 7-8 hrs just for normal work.
Instagram, Facebook and Youtube app normal la ve battery consumption athigam irukumnga. from the graph, yes its higher and just as an example if you are using instagram in safari browser, you will see good difference in battery consumption. But app wise it uses more cpu, gpu power when we watch videos bro.
usage irukumbothu in between days charge pannurathu problem illainga.
Normal la phone calls, messages, whatsapp 30 minutes around video streaming nu use pannumbothu one day backup irukumnga.
Instagram is the battery drainer in iPhone and Android. But due to higher mAh in android phones, athiga neram use panna mudiyumnga.
one or two days instagram usage athigam illathapo eppadi iruku nu paarunga. that will help us to understand better too.
Use Low power mode on 20% below it’s iPhone thing
