Na iPhone 15 September la purchase panen battery health till now max capacity 96 showing and cycle count 94 showing is this normal or any battery issue irukuma robin bro Konjo soluga ???
hi bro, for 9 months usage and 4% reduce is totally normal. dont worry. charging practice continue pannunga. it will be maintained according to your usage.
Robin bro above la irukara battery paruga is this okay va because of it battery percentage max reduced ah bro???
its good bro. when you used it reduced gradually. and idle time battery well maintained. continue using it bro. do charge it when it reaches 20%. that will help.
Thanks robin bro
