I brought iPhone 15 on October 5 128 gb matt black
Still now battery health 100% and cycle count is 40
I use iPhone for mainly calls
I have 2 Android phones tab and pc
So my iPhone usage is less .
Is there any issue to use little or i should use more time ?
Main question is , for example night while sleeping my iphone battery percentage is 75% . In morning i check my phone it reduce 3-4 % .like it shows 72% or 71%.
What’s the solution robin bro and friends?
Hi bro, as I mentioned in todays episode cycle count and battery health calculation will be bit different. not same for all users. so continue using your device the way you want. and measure it 5 to 6 months once. that will help to measure battery health better.
overnight upto 8% drain is normal based on my observation. for notifications, network usage etc.,
Continue following the charging practice and it will be maintained well bro.
Ok bro thanks for your response
Bro na mobile vangi 2 month tha aachu athukulla battery percentage 98 ku vanthuruchu cycle count 56 iruku enna pandrathu eapdi maintain pandrathu bro
Bro na usage kami ah dha panren .44 count 100% iruku. 20 vandha charge podvn , 95 varaikum charge poduven. Robin bro Channel la battery maintanence vdeo irukum parunga bro
